Need Help Finding Amp Kit
ddog003
Hey, I just got 2 Infinity Kappa Perfect 10.1d subs and an Infinity Reference 611a amp to power them. I was just wondering what would be the ideal amp kit for this and if anyone knows where to get one for a good price. I am also a bit condused on how I should wire my subs to my amp. Is this amp good for these subs? Here are the specs below. Thx.
Each Sub
Rec. Sealed Box Dims: .6 - .6 cu.ft.
Rec. Ported Box Dims: 1 - 1 cu.ft
Free Air Usage: not recommended
Sensitivity: 94 dB
Frequency Response: 18-150 Hz
Recommended RMS Power: 350W
Peak Power Handling: 1400W
Impedance: dual 4 ohms subwoofer wiring options
Amp
Amplifier Type: Mono
RMS Power: 456W x 1 @ 4 ohms
THD at 4-Ohm RMS Power:
Bridged RMS Power: 657W x 1 @ 2 ohms
Speaker Level Inputs: no
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0 - 12 dB
Frequency Response: 17-302 Hz
Signal to Noise Ratio: 70 dB
Fuse Rating: 2 x 30 amps
Ideally, you would want two dual 2 ohm subs so you could wire them to a final 2 ohm load on the amp getting 657 watts to the subs. You can wire two dual 4 ohm subs to a final 4 ohm load or a final 1 ohm load. I'm not sure that your amp will be stable running a 1 ohm load. Some amps are but many are not. If you wire the subs to a final 4 ohm load you will get 456 watts from the amp. It will work but it isn't the most efficient setup.
Here's a link to some sub wiring diagrams. Select your setup on the pulldown menu.
http://www.infinitysystems.com/caraudio/sub_wiring.aspx
ddog003
ddog003
Phoenix, AZ
crow
