Need Help finding Amp Kit
ddog003
Hey, I just got 2 Infinity Kappa Perfect 10.1d subs and an Infinity Reference 611a amp to power them. I was just wondering what would be the ideal amp kit for this and if anyone knows where to get one for a good price. I am also a bit condused on how I should wire my subs to my amp. Is this amp good for these subs? Here are the specs below. Thx.
Each Sub
Rec. Sealed Box Dims: .6 - .6 cu.ft.
Rec. Ported Box Dims: 1 - 1 cu.ft
Free Air Usage: not recommended
Sensitivity: 94 dB
Frequency Response: 18-150 Hz
Recommended RMS Power: 350W
Peak Power Handling: 1400W
Impedance: dual 4 ohms subwoofer wiring options
Amp
Amplifier Type: Mono
RMS Power: 456W x 1 @ 4 ohms
THD at 4-Ohm RMS Power:
Bridged RMS Power: 657W x 1 @ 2 ohms
Speaker Level Inputs: no
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0 - 12 dB
Frequency Response: 17-302 Hz
Signal to Noise Ratio: 70 dB
Fuse Rating: 2 x 30 amps
Each Sub
Sensitivity: 94 dB
Amp
I would say 4 guage amp kit with a ANL fuse holder.. And the subs wired parallel. Positive-Positive........Negative-Negative....down to 2 ohm
Each Sub
Sensitivity: 94 dB
Amp
There are only two practical ways to wire those subs. And only one that will work with your amp without blowing it up.http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp=Dual+Voice+Coil+-+4+ohms+x+2
Use the one that puts the subs to 4ohms. Or buy dual 2 ohm subs. Or buy a new amp.
thats why it pays to research this stuff ahead of time //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
ddog003
ddog003
Phoenix, AZ
.::DuD3::.
