Need help finding a good USB
SWFL
I am looking to get a USB something like 4-8-16GB. I was wondering if there is any brands I should or shouldnt look into. I am on ebay and found some 16bg for like 25 bucks, its going to be only to put music on it and hook it up to my CD player for tunes. so does it matter or should i watch out and not buy the off brand will they really have 16gb of storage and work fine with my pioneer 6000ub
Thanks
no problems with it????
Just not sure if I should use a kingston or grab a cheap one and have double the space, how many songs fit on that 8gb???
I didnt know if certain usb brand will have a better qualitly and sound better being as I am using it for music
all usb drives are the same. just get the cheapest one. the only thing I can think that matters is if it lights up or not.
Ignorance is bliss I suppose ...
MTBF between MLC and SLC flash memory ?
Read and Write transfer rates between MLC and SLC flash memory ?
Transfer rates between USB controllers under saturation ?
Quality of enclosure material and design ?
Sound better ? No ...
Last longer ? Yes ...
Transfer songs on and off the drive faster ? Yes ...
My recommendation = Sandisk Cruzer Contour
The newest Sony ones are decent (~15 MB/s transfer, decent build/design), but the older ones are poorly made (plastic, terrible slide design that breaks easily).
as jmac said they are basically all the same except for transfer speed and build quality....SLC>MLC btw
if you are going to transfer mp3's to it once, use it for playback and not going to carry it around much just get a cheap one
if you are going to transfer mp3's back and forth to it a lot and carry it in your pocket or on a keychain get a faster one with a decent case
of course if the pc you are using to transfer the files is not USB 2.0 then the speed thing won't matter at all. transfering 16gb of data through USB 1.1 will take a while....days
This is what i'm rolln' on my keychain. its absolutely the shit.....waterproof, you can even drive over it with a car.
https://www.ironkey.com/
SWFL
SWFL
us
cardinalsfan
