Need Help Fast
J_AUSTIN69
I HAVE (2EA) EARTHQUAKE MAGMA 12 SUBWOOFERS AND IS LOOKING FOR THE PERFECT AMP TO DRIVE THEM
SURROUND: PRESSED:2" THICK FOAM
MAGNET SIZE: 95 OZ
RMS POWER: 1000 WATTS 500 WATTS PER VOICE COIL
VOICE COIL: DUAL 3ohm 3 inch
SPEAKER SIZE: 12" //content.invisioncic.com/y282845/emoticons/omg.gif.05aa02c3095d6ce9338996654eca0863.gif
You say that you have 2 12 dual 3 ohm subs that are 1000 watts rms per sub?
If you used one amp to power the two subs they would be wired for a final load of either .75 ohms or 3 ohms.
Now if you wired them to one amp per sub which would be two amps you could wire each sub to a 1.5 load. If you did that I'd go with two Hifonics 1500's. They would put out around a 1200 watts at 1.5 0hms give or take depending on the voltage. Or you could go with the Hifonics BX1000 which would probably work just fine and not melt your alternator.
http://www.woofersetc.com/product.asp?0=295&1=296&3=2044
not sure what ur impedsance will be, but check brutus hifonics,
and c what ohms can it handle, if it can handle less than 1 ohm then its good 4 u
wait for other commenst from other ppl
Actually it looks like they are 1500 watts max which means they would be 750 rms. I'd look into the Hifonics BX1000D, one per sub. Or ask someone if the Hifonics can run @.75 ohms and then you could use one BX1500d or BX2000d.
J_AUSTIN69
J_AUSTIN69
CHICAGO HEIGHTS,IL
DFW40
