Need Help Fast With Wiring(maybe bad relay)
couagajl99
ight i used a 30 amp relay from cardomain to turn on 2 amps a crossover and 4 led lights i use my remote off of my head unit to use for the the turn on and turn off i checked the wireing and turn on the hu to see if everythang would work and it did
so when it came to hook'n up the power wire for my amp and caps i got the normal spark that i usually get. but after i did that my leds and crossover kicked on and wouldn't turn off so i pulled the fuse off of the power wire i had ran to the relay and they still stayed on, so i was like what the hell. so i went back to my 8 slotted barrier stirp where i had thangs hooked up too and start to pull fuses that i had hooked up, fuse for each amp, fuse for the cross and i had the leds on one fuse
i am completely stumped here need some advice quickly
wire up the remote turn on leads to both amps... in a daisy chain.
then take a relay and hook it up to the remote wire on one of the amps. into 86 of the relay.
ground to 85
hooke up 12v fused to 30 and the led out to 87
couagajl99
couagajl99
Coshocton, OH
couagajl99
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
