Need help designing ported box for 2 12" type r's
make a log and let everyone know how well the "free" design worked out //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i need to start charging for box designs lolz
Would you recomend that design for the R's even if you had room for 4 or 5 cubes?
if you want to push 1kw or more yes if no more than 800-1000 maybe 4.5 cubes per pair at the most depends what you want. i have done many dif ways and 3.5 per pair on 2kw at 38hz has always sounded the best and been the loudest overall.
I aint no drafter, but I drew up a sketch for you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I forgot the height on the vent, its 12.5
i used this one, and it just seems to small for these subs. This is for the swd-1242's right???
I'm too lazy to calculate it.. what's the internal?
3.56ft^3 before any displacement, nowhere near enough for 12's...still kinda small for 10's. Not to mention it isn't designed right anyways. When the port splits in the back, you need to have half of the wider part of the port go each way, so 1.75" from the back wall for each port, then funneling into a 3.5" port.
asager203
asager203
Canton, MI
Jaredturp
