Need Help, Couple questions???
Kaizer_Sozay
Thanks in advance,,, Ill break this down into parts.. and any other sujjestions would be helpfull....
Background:
Car is a 02, accord coupe, i have an upgraded alt, will do the big three and in time get an optima red or yellow, Instal will be done by a pro, dynomat and stinger bullet RCA's, and 2 4 gauge lines to the amps (no one here has 0 gauge //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif )
Present component : Eclipse 8455 HU, Koda 8's; run buy RF 4004,
1: need advice on componets...like focal K2 (budget for utopias i dont think is there), but they dont sell them here so maby type x alpine, or infinites....
2: Stock tweeter, and door mounts will be used, and the 8's wil be in the back deck, i dont want to cut the car appart, i know they would sound better in the front. Cross over around 70-160
3: amp to run the comps i was looking at Jl 300/2 or zapco not sure which is better SQ (150 rms for the focal comps, , 75 rms for type x)
4: which is the better sub for SQ w7 or w6v2, and an apporpiate amp for running both..
6: if anyone knows the sealed box size for Koda 8's to make an inclosure pleaz post.
7: the 4g wire one dedicated to the sub amp, and one split to the mid bass and componet amp,,, any pros or con's about this instead of one 0g to the ampss then split
thanks in advance, i know this is alot of questions but i could really use the help,,, im still a novice at this game, i know numbers and stats but no real life experance in hearing the multitude of setups and products..
My listing tast range from jazz, to punk, to top 40 stuff,,, looking for front stage that have a "liquid" sound also because the tweets are pointed at the front widshiled i think i might have to go with a brighter tweet, hence the focal k2 but not sure just a thought i had.
Kaizer_Sozay
Kaizer_Sozay
Ontario
Kaizer_Sozay
