need help choosing amp
ritzthekracker
hey i was wondering what amp i should get for 2 rockford fosgate RFP4410 subs. here are the specs on them:
* Sensitivity: 85.4 dB
* RMS Power Range : 200 Watts
* Peak Power Handling: 400 Watts
* Impedance: 4 Ohm
* Low Frequency response: 32 Hz
* High Frequency Response: 200 Hz
* Diameter: 10 Inch
Features
* polypropylene woofer cone
* large roll foam surround
* CONsealer gasket hides mounting screws and provides an airtight seal
* dual-laminated flat spider for maximum linear control of the cones travel
* 25-ounce magnet
* 1-3/4" voice coil with aluminum former
* frequency response 32-200 Hz
* power range 50-200 watts RMS
* peak power handling 400 watts
* sensitivity 85.4 dB
* 4-ohm impedance
* top-mount depth 5-3/8"
im tryin not to put too much money into this so any help will be greatly appreciated.
ritzthekracker
ritzthekracker
Salinas, CA
Decipha
