Need Help Choosing 4-Channel Amp 150Wx4 @ 4ohms
zaftafa
I currently have 4 a/d/s speakers which a friend bought for me a long time ago so I don't know exactly which model they are but the instruction manual is for 234im, 235im, and 236im. I am looking for a new power amp that can put out full power to these speakers, they can handle up to 150W @ 4 ohms according to the instruction manual. Please advise on which amp would be the best for the job. Thank you.
I am also using a JL Audio 12w6v2 subwoofer and I will be installing a PG X600.1 to power that. Right now the speakers and the sub are hooked up to a Soundstream TRA880.5.
You can probably get a PG Xenon 200.4, that does 200x4 @ 4ohm. That will go well with your bass amp...
Or you can look into a JL HD 600.4, that does 150x4 rms @ 4ohm
you could try a crescedo c1000. I know its only rated at 125x4 at 4 ohm, but still thats some serious power. Definately woke up my pheonix golds vs my Rockford p400.
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
zaftafa
zaftafa
pomona, ca
Team Maxxsonics
    May 19, 2024
    May 19, 2024
