need help arc ks300.4
b8sah0l1c
just got the ks300.4 install in a 08 tahoe with bose. the amp is powering 2 set of diamond audio s600s. now using an adapter for aftermarket amp the cleansweep is on its way. anyway it sounded pretty good but the amps keep cutting out at high volume then comeback on and plays fine. i just cant crank it up much. what could be the problem. cant be the battery cause the tahoe has a 160amp alt and the voltage meter show 13.9 to 14.2. no sub amp is hookup yet.
b8sah0l1c
b8sah0l1c
Richardson, TX
b8sah0l1c
michigan born
    May 14, 2026
michigan born
    May 14, 2026
