Need help adding an amp (2 or 4 chan)
Bump guys, So should i do just a 2 chan and unplug the rear doors? that seems weird to me...
Or should I do a 4 chan and run the front doors off front channel amp, rear doors (stock) off rear channel amp and tweets off HU?
Does that make sense, is it logical? KHA please chime in...
So should i run just a 2 chan or a 4 chan?
2 chan i would run the front door 6x9's off amp, tweets off HU and dis connect the rear door speakers which are stock.
Or, should i get a 4 chan, run front door 6x9's off amp, rear door 6.5's (stock) off amp and Memphis Audio tweets off HU?
Please, somebody answer this post... More than appreciated!
Bro.
Run only front speakers.
For the last time.
Unless...
Your not too worried about sound quality or high end acoustics.......
If so, and you just want a decent setup to listen to riding down the road, run it however you want.
It's simple.
If you want a high end system with great acoustics, run only fronts.
If that isn't your goal, then run it however you want.
Then later, put your midranges in the floor, and run door midbass off the remaining 2 channels on your amp.It's all about keeping everything up front
Appreciate that input man, that's what i did and it's great. Thanks for your time.
Staynlean
Staynlean
Memphis, TN
Staynlean
