Need help adding a sub
  • 1
Deamonicus3
PyRaMiD AmPs RuLe!!!!!!
I've got a JVC HU connected to a 4 channel amp. The amp is only running the front speakers. I had to use an loc to hook up the amp to the fronts. The rear speakers are running off the hu. Theh loc has another set of rca's and so does the hu. I would like to add a 10" sub in the trunk. I want to go with 10" because of space and power issues. If I bridge 2 channels of the amp I should be able to get 150 wrms. Can anybody suggest a decent amp/box combo and tell me how to wire it all up? My budget is under $150.
601
704
953
Deamonicus3
Deamonicus3
Homestead FL
Deamonicus3
    May 12, 2024
Brendon Jenness
    May 11, 2024
