kicker comp vs alpine type-s in SQ
Depends on what your idea of "better" is. The Comp VR gets decent loud and sounds decent. The Type-S doesn't get quite as loud but sounds pretty good.
install depandant, and userdefination of SQ which would sound better...to some,more bump in a system sound better, to some, a flat line sounds good...so....
no the new type s's are great. I just installed them in a friends cars saturday nite. He love them, BUt the SQ of it is good, and they run $150 retail.
personally, i wouldn't get either one.....
i'd get the memphis power reference....gets louder then the comps (vr or otherwise) and sounds better (totally subjective)....better warranty then both.
but if i had to choose between those two..i'd get the comp vr...then the type-s..then the comp.
check into the pr's..u can get a pair for $150 (depending on size)....best mainstream budget sub on the market!IMO
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
i have the PR subs, but i would rather have the Type R's , but of corse i love SPL. BUt i do not have the PR in a sq type set up. THey do not need as much power as the Type R's tho.
the pr's are indeed extremely efficient..i have mine off 70wrms and most ppl think there is quite a bit more in my truck.
again, for the money, u can't beat the pr line of subs..IMHO
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
You will need a wiring kit too so a little over budget. Depending on if you're going to build on this with an additional amp for rears and a sub...
4
128
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
843
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
cowboyjmt
cowboyjmt
imperial,pa
mrray13
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
Latest topics
