Need Enclosure Help
tweak
I got an 01 isuzu rodeo, Right now I have 3 10" Kenwood Excelon 4ohm dvc's ran to 2 ohm powered by a fosgate 1001bd power series amp. The sealed enclosure now 1 cubic ft per sub, facing back in the cargo area, bumps hard! My problem is between camper and boat, I have to take the box out for room. I need some type of enclosure that would take up the back floor but not real high and the subs would be protected/ hidden, so that stuff/gear can be put on top with out chances of harming subs. But they still need to perform. Any suggestions would help, thanks
kdc-x1025db
sealed recomendations are .6-1.25
and ported .75-1.5.
depends on the total height of the sub and total height of your rear area but i'm sure some sort of mdf baffle accross the entire rear floor and maybe another peice of mdf a little above the speakers with holes drilled in it like a grill above each speaker. but that may or may not be too tall depends on the total height you have ot work with
the speakers are about 7" bottom of magnet to mounting ring, how much room should there be between the magnet and the box? then how much room between the face of the speaker and the baffle?
tweak
tweak
jersey
tweak
Mike Mccabe
