Need DEI Harness for Viper 5901
NO1B4ME
I had a free lance install an alarm in my 07 Toyota Tundra and for some reason had to return it and get an 08 Tundra. I called this guy up and he was not able to remove the alarm from the 07 Tundra so I decided to remove it and re cable it back into my new 08 Tundra. Well after seeing how bad this installer cut my factory harnesses I was shocked to see what he had done. So I decided to put it in my new truck myself as the install cost was 400.00 for the 07 Tundra. Please understand I did not care about cost as this is a expensive truck, but heck my panels were all scratched up as it looks like he used a pry bar or screwdriver all over my truck panels.
I am definitely scared to take my new 40k truck to anyone and will not go through this again. I decided to do the alarm on my new truck myself as I am an electronic savy person and don't feel like paying someone 400.00 again and maybe go through the same dilema again.
So I worked on this install for 12 straight hours and have the alarm 90% complete but decided to get a new harness to redo it completely. He cut the harness wires so short as he put it right beside the fuse panel //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif:mad://content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif. I could literally open the door and remove the alarm in seconds....
I called DEI and they will not help me with a new harness. Can someone local get one and pm me or reply back here?
DEI wont send one to you? I thought they were only 15 bucks for new ones....maybe thats only through a dealer though.
EDIT: I just talked to some friends and they said they have called for customers and then DEI wants to speak to the customer to complete the order...
I talked to a local that will try to help me out.
is it a standard 12 pin DEI harness? I have a new one left over from an install I did last week.
This is the harness i need....
H1/1 RED/WHITE (-) 200mA TRUNK RELEASE OUTPUT
H1/2 RED (+)12v CONSTANT INPUT
H1/3 BROWN (+) SIREN OUTPUT
H1/4 WHITE/
BROWN
LIGHT FLASH -ISOLATION WIRE - PIN 87a of
onboard relay
H1/5 BLACK (-) CHASSIS GROUND
H1/6 VIOLET (+) DOOR TRIGGER INPUT
H1/7 BLUE (-) TRUNK PIN/ INSTANT TRIGGER INPUT
H1/8 GREEN (-) DOOR TRIGGER INPUT
H1/9 BLACK/WHITE (-) 200mA DOME LIGHT OUTPUT
H1/10 WHITE/BLUE (-) REMOTE START/ TURBO TIMER ACTIVATION
INPUT
H1/11 WHITE PARKING LIGHT OUTPUT
H1/12 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT
NO1B4ME
NO1B4ME
Wesley Chapel,FL
dbaudio
vegang
vegang
