Need box help for Pioneer Premier TS-W3001D4
When I had my 3000spl it sounded great in 2.3cuft@35hz. It was pretty good on the lows and still sounded pretty good for what it was. It took a while to break it in, but once it did, I loved it. I was gonna do 3-4 but it was hard finding more of them. I had the older ines, but the specs should bbe about the same. They sound great sealed also
No.You need around 3.2cuFt
Oh man, This is what I have got 2 of mine in, dam, heres a link, so your saying this is way to small and am I not getting full benifit out of them, Am I choking them would you say because they sound very good to me and drop low
Should I build another box ?
These subs do well in as little as 1.25 cu.ft. ported. However, with that little airspace, your port is going to have to be quite long.
I have my pair of 2000SPL's (older model) in a 4.5 cu.ft. box tuned to 33hz with 48 cubic inches of port area. There is no port noise unless you hit the tuning frequency and are sitting in the back seats and the cut off frequency is 29hz. I've also had them in a 2.5 cubic foot box tuned to 44hz.
3.5 cubic feet for a pair tuned to 35hz with around 35 cubic inches or more of port will sound pretty good if you can feed them full power. If not, make the box a bit bigger to compensate.
Jeepjones85
Gold Power
Jeepjones85
South-East AR
riddla
