Need box help for MA Audio HK12 1500 RMS, LOST
Bobbby
6
Pa
--I recently came across a good deal on an MA Audio HK12 1500 watt RMS subwoofer. This is my first time building my own box and I'm hoping I get it right. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
It's hard to find information out there for this sub, but I've gathered all the details I could and I'm hoping someone here can give me some insight on how to go about this.
Features:
MA Audio HK12 DVC Subwoofer
3000 Watts Power Handling
1500 Watts RMS Power Handling
400 Oz. Double Stacked Strontium Magnets
Aluminum Round Wire Voice Coil
Hi-Temp Kapton Voice Coil Former
Patented Thermo-Cooling Motor Structure
Bumped Back Plate for Max Excursion
High Roll Triple Layer Ribbed Surround
Double Layer Progressive Spiders
Dual Layer Pressed Carbon Fiber Cone
Ultra Strong Carbon Fiber Dust Cap
Rubber Sealant Gasket
Specifications:
Sensitivity: 88.9 dB@ 1w/1m
Impedance: Dual 2 Ohm Voice Coils
Diameter: 12"
Mounting Depth 8"
Mounting Diameter 11"
Vented Box: 3.0 cu/ft
Port: 48 sq/in 14.5" Long
Sealed Box: 1.5-2.25 cu/ft
I want to do a ported box for my Jeep Cherokee. There's plenty of room in the back, so size shouldn't be an issue, and I have a 1200 watt amp for this too. Any help would be greatly appreciated! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Here's a pic:
and as far as sound preference goes, loud and clean!
I have had that sub. First off, Its quite the sloppy bass. Why? Its a competition, SPL subwoofer, and only is good for high notes.
Secondly, the softparts inside of it ****, the surround wears down very quickly, and the sub has really thin coil. It sucks, save your money on something else.
But don't get me wrong, that thing does slam.
^ that's what I'm saying! I just went to the local audio shop and they said MA recommends a 3.0 box, which I already knew, but I was trying to compensate for the size of the sub itself by building a 3.25-3.5 cu ft box, but apparently MA already does that and a 3.0 will work fine.
How about this one:
12" CUSTOM-VENTED CAR SUB BOX ENCLOSURE 3.0 ft^3 @ 35Hz - eBay (item 170479696680 end time May-29-10 22:32:21 PDT)
??? I'm too antsy, might just order it and get it in.......
If your getting a prefab, which is yuck IMO, get one tuned to 32, cause that bish will slam the low notes.
Bobbby
Bobbby
Pa
jdawg
