need an amp for my 13.5 inch JL adio W7
  • 2
Hello all,
I have a 13.5 inch JL audio sub. I need a new amp just to run this sub by itself. Here are the specs...
13W7AE-D1.5(Model) 13.5-inch (345 mm) Subwoofer Driver
Continuous Power Handling (RMS) 1500 W
Recommended RMS Amplifier Power 500 - 1500 W
Nominal Impedance (Znom) Dual 1.5 Ω voice coils
price isn't really a problem, just want to make sure everything goes together and works properly and efficiently. The part that gets me is that above it states that the recommended RMS amp power is between 500 and 1500. That's a pretty big gap. I prefer to go with a Rockford amp, mono of course, but don't know if I need the 1000 or the 1500 watt amp. thinking about the Rockford Fosgate Power T1500-1bdCP 1500 watt amp. thnx guys
Well you either have to wire to .75 or 3. A short answer is the RF 1500 will work for you, but it may not be the best choice.
651
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
960
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
SinCityBlue03
SinCityBlue03
Temecula, CA
Chriszle
    May 16, 2024
    May 16, 2024
