Need amp help! Im buying one of these tonight..
cashmoneygreen
Harlems Back
6
Whatsup guys
I just recently purchased the Kenwood KFC-W301 4 ohms svc 2400 watt total
Im going to wire them at 2 ohms
Im wondering what sub use.. I narrowed it down to 3...
Kicker 900 watt mono d- http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280233272801&_trksid=p3907.m32&_trkparms=tab%3DWatching
Kenwood 1000 watt mono d- http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300228376404&_trksid=p3907.m32&_trkparms=tab%3DWatching
MTX 900 watt mono d- http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350064258523&_trksid=p3907.m32&_trkparms=tab%3DWatching
Even though the kenwoods 1000 watt would it make that much of a difference as opposed to the 900 watt subs?
Whatsup guys
You do realize that those amps give out about 300-400 real watts only. I dont know if thats enough for 2 subs. Then again what are the specs on the subs.
12" subwoofer with 4-ohm voice coil
stainless steel-coated polypropylene cone with rubber surround
power range: 50-400 watts RMS (1,200 watts peak power)
frequency response: 25-800 Hz
sensitivity: 90 dB
mounting depth: 6-3/4"
sealed box volume: 0.8 - 1.75 cu. ft.
ported box volume: 1.0 - 2.0 cu. ft.
if they cant power these subs...what is a good amp to get? I really need your guys help as you can see I know nothing
12" subwoofer with 4-ohm voice coilstainless steel-coated polypropylene cone with rubber surround
sensitivity: 90 dB
Box size and type determines power handling... what box are the subs in?
Your thinking is backwards... if you have more subs it will take less power to reach the same volume level (up to a certain point), so if one of those amps will run one sub just fine, then it will be more than enough to run a pair of them.
cashmoneygreen
Harlems Back
cashmoneygreen
benchambers80
