Need amp help for my Dayton HO 10"
kevin25
I have a Dayton HO 10" and I am currently powering it up by my Kicker 750.1 Mono amp.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19319
The 4 ohm Dayton can handle 600watt rms but my amp at 4ohms only puts out 375 rms:(
Do you guys suggest I get another amp? I am not sure if I should stick with mono amps or just bridge an amp to get more rms. What is the difference here between the two.
Oh yeah if there is no difference what about this amp, puts out 600 x 1 @ 4 Ohm
bridged.
http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=125&idproduct=382
Or this one that puts out 600x1@4ohm
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19667
My Neon Srt4 came with a custom kicker livin loud system. In the trunk was a small enlosure that housed a 10" kicker, I took that kicker out and installed the dayton 10". I am not sure on the cu? I no it is sealed though
What box do you have and is it ported and what is the cu of it?
kevin25
kevin25
Michigan
kevin25
