need amp for 13w7
Ok I decided to go with the sundown. Do I need to put a fuse on the power cable? The manual isn't clear. It says I need one if I were to get the 3000d put not the 1500 because the 1500 has 4x40 amp fuses but later down themanual it says it is a must to match the power cable fuse to the same as the fuse in the amp so Do i need a 160 amp fuseson the power cable or not at all? Is this a better amp then the 1000/1v2 jl amp? Mysub can handle 1500 will it be able to handle the extra watts since I am going to .75 ohm. Thanks a lot for the help
if you go to 1500rms you will void the warranty i would stay towards 1200rms as the aq or the jbl are
it would probably be right on 1500 watts. how would i adjust the gain so i dont bottom the sub out? like on the jls you use a voltmeter and turn the gain up until you hit a certain number of volts. is there a chart like this for the saz-1500d
jordan572
jordan572
minnesota
LDW3RD
