need advice
Curren$y
i have a cheapo audiopipe apsm1500 and i want to upgrade to a sundown.
stock electrical knukonceptz ofc 4ga 150a mini anl fuse/2 12" re audio se-xs wired to 2 ohm
my question is, should a get a sundown 1200 watt and rewire subs to a .5 ohm? or should i get a sundown scv 2000 watt and pull the 1000 watts?? (because im assuming the 1000 watts from the sundown would be cleaner power than the audiopipe)
Hope you got a good box because if not its not gonna make a big of a diff if its not a custom enclosure talk to CSCStang and he can make you a box that even with that audiopipe itll sound better
570
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
665
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
925
Curren$y
Curren$y
Dallas, TX
Curren$y
Decebal
    Jun 10, 2024
