Need Advice?
This Cadence Txa6004 will be a nice amp to run the comps and sub. you can run the 3rd and 4th ch. bridged to the sub and ch. 1 and 2 to the comps.The amp is 25 inches in length so make sure you have room.
http://woofersetc.com/p6099/TXA6004--Cadence-4-Channel-High-Power-1200-Watt-Amplifier.htm
i don't know much about the pg comps but their specs say they are rated at 60rms. the 6004 does 150rms per channel @ 4ohm. the 3004 would be a better choice i think for this application.
Ok guys I have been looking real hard at two amps. They are the Cadence TXA300.4 and the Arc Audio FD 4150. The Cadence seems very reasonable and I may be able to pick up the Arc within my budget as well. Tell me what you all think of these two amps.
Once again thanks for your input.
ndirish
ndirish
Elk Country
nineball
Mike Mccabe
