need advice on my new system
cynicz
Ok basically my trunk opening is like 14 inches tall 32 inches wide. trunk has about 40 inches depth it can use, and at a angle i can fit an approx 15-16inch tall box. Right now i got a 14inch tall 30 inch wide 31 inch deep box with 1 15inch IA LI.
Im debating on my next system. The biggest alternators I can find for my car is from ohio gen and its a 200 amp alt for a kia forte.
I was thinking 4x SA-10, with a AQ 3500, 2 Deka 9a31 batteries + stock. box was going to have 3x 4inch aero ports tuned to about 32Hz along with the 200 amp alt.
Can anyone give me any more suggestion for a loud system I can fit in that space. I was thinking about just walling it off but the car is pretty new and its 4 door so would be weird having 4 doors and only using 2.
4 dcon tens on a sundown 1200 or audioque 1200 would be pretty loud depending on install and wouldn't tax you electrical as bad meaning alt and "extra batt/upgraded stock" may only need a bigger alt but I'd look at other companies Alts Ohio gens have their idle points set to high to be on at true idle. plus it would be cheaper just my .02 cent with my experience with ssa
Yea I like the sundowns but in your situation I'd suggest either finding a bigger alt or downsizing the electrical requirement cause with out doing one or the other you will prolly have a trunk full of batts and not much room for a box. Of course Idk how your voltage will do with just the two dekas this is just my observation. I had 3 xs3100 on my sundown 3500 and I dropped a little but that was fixed with a bigger alt 130 to 270 was a big jump try emailing dc power Alts they might can help u but it really depends if the alt is computer controlled or not cause they didn't want to touch my cruze alt cuz of the computer controls
@ winky I alrdy got a aq1200 on a 15 LI but I want a 3-4k watt system not another 1200 watt system :p
@ phoenix will try that because the dude said he was pretty sure tibs and the forte have the same alt
cynicz
cynicz
illinois
cynicz
