Ecky
When I bought my car early this year, all 4 stock speakers were crackling and fuzzy. I got a set (4x) of Rockford Fosgate R1653's off a friend in return for some computer help and replaced the stock speakers. I don't remember what size the stock speakers were, but I had to make some modifications to the mounting brackets to get them to fit. In the front, they're no longer mounted to the frame of the door but to the plastic (I think) panel. There's a little bit of isolation but the panel is not stiff at all. In the rear, they're basically open-air, behind a plastic mesh.
The head unit was already aftermarket when I got the car - a Panasonic CQ-RX200U.
My problem - I need to max the bass output on the head unit before there's any low-end at all, and doing this causes the speakers to distort at an inadequate volume. At first, I was thinking of getting a small amp since the speakers are definitely underpowered, and that might improve the bass response a little, but I'm thinking now of building a small sub box behind the seats. The speakers sound fine as long as I'm not maxing out the bass on the head unit.
I'm not looking to rattle the cars next to me, I just want full range sound, and I'd prefer not to dump money into it. I'm hoping to use something like a 6 or 8" woofer in a sealed box with a small dedicated amp... should I get an amp for my other speakers as well? What's the best way to wire it?
The head unit has a sub output in the back, with a digital crossover you can set to 60hz / 80hz / 100hz / 200hz, and I've played with it a bit with a computer sub hooked up to it but it sounded pretty crappy, should I avoid this and just use a real crossover? Maybe put the sub+amp on on the head unit's rear channels and the 4 speakers with a small amp on the front channel?
Are open-air/boxless car subs any good? It would definitely be a space saver.
What do you guys think?
