Need advice on an Amp for a single 10" old Kicker sub
I think it is an old 10" Kicker Competition and Freeair C-Series sub (pictures below) and I need an amp for them.
It is sealed in it's box and don't want to have to take it out if I don't need too. So I can't see the back. From what I found on the web and based off the picture I found of it below. I think it is 8 Ohm, RMS rating "Pmax, watts = 300" off the manual I found. Does that sound right?
Just looking for some advice on what amp I would need for it.
These are not pictures of "my" sub but I am 95% sure it is the same one
http://img685.imageshack.us/img685/4676/b65ygcgkkgrhqqokiey7wqb.jpg
http://img69.imageshack.us/img69/9696/b65egqewkkgrhquoknqey1l.jpg
I think this is the manual for them off the kicker site http://www.kicker.com/sites/default/files/FcMan.pdf
Ok I think I figured this out on my own. Please correct me if I have anything wrong.
Sub is 300 peak = 150w RMS. 8 Ohm
So
Amp would need to be:
Mono / single channel. 600w @ 2 Omh (150w @ 8 Ohm)
Or
Dual channel. 300w X 2 @ 2 Ohm (75w X 2 @ 8 Ohm)
Is that right?
do you think this will be the only sub you use...or do you think down the road you might want to replace the sub?
Yes for quite a while unless this old kicker blows out. But it would just be replaced with another singe 10".
It seems most modern 10s are 4 Ohm so getting a 600w @ 2 Ohm amp would give me 300w @ 4 Ohm to work with for a replacement need be. Unless I am missing something.
I am just going to post these because if you have been around awhile, you probably know the quality...most who bash them either mistake them for another brand, or mis-used the bigger amps and fried them with too low a voltage...and it is hard to find authorized dealers now days.
..it says stereo, but it is a typo, it is a mono class D..
http://www.techronics.com/caraudio_11788_Alphasonik-PM1600DE-600W-Class-D-MonoBlock-PM-Series-Car-Subwoofer-Amplifier.html
this one has the remote voltage meter, 2ch A/B...clean and does rated...but it is a big bastard.
Alphasonik PMA2150A 2-Channel Class A/B Bipolar Power Car Audio Amplifier
OldSchoolKickr
OldSchoolKickr
Mission Viejo, ca
ACE74
