vandiar2
Running 2 MTX 12's 225 rms a piece. What would be a good amp to use to get the full potential out of these 2 subs? Thanks in advance!
150-250 dollars. I want something that is going to give the best bang for the buck though. clean deep sounding bass. I was told getting a 600 rms at 2 ohms and setting the gain down would probably be best . I just don't know though, hence why i am asking //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifOk, so you want something that will run 500 watts at 2ohms.
How much do you want to spend?
I would recommend getting the most power you can for your price range and then adjusting the gains down to the level that you need. If you can pickup a 1,000 watt amp for that (which you may be able to do) then do it and adjust the gains down and just keep the extra headroom incase you change out subs.150-250 dollars. I want something that is going to give the best bang for the buck though. clean deep sounding bass. I was told getting a 600 rms at 2 ohms and setting the gain down would probably be best . I just don't know though, hence why i am asking //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks for the response btw. I guess the better question is.. what brand amp is recommended? I hear a lot of talk about alpine amps. Good sub amps? I am running a kenwood 4 channel amp on my fronts and rear and it sounds great. kenwood have good sub amps?I would recommend getting the most power you can for your price range and then adjusting the gains down to the level that you need. If you can pickup a 1,000 watt amp for that (which you may be able to do) then do it and adjust the gains down and just keep the extra headroom incase you change out subs.
Check the classifieds for amps, I'm sure there are TONS in that price range for what you want.
No problems on the replies. There are literally dozens of good brands out now. On this forum, sundown gets some of the best reviews. They won't have something for you in your price range though.Thanks for the response btw. I guess the better question is.. what brand amp is recommended? I hear a lot of talk about alpine amps. Good sub amps? I am running a kenwood 4 channel amp on my fronts and rear and it sounds great. kenwood have good sub amps?
Please click his name then click private message. Keep on topic //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifwhat up josh
dang that is a good deal. pm senthttp://www.caraudio.com/forum/showthread.php?t=365285
its pending but may still be for sale. 500 watts at your required ohm and a darn good amp
