Hello everyone. I need some serious advice..... I bought 4 infinity kappas 62.9i and an infinity 5350a 5 channel amp. I hooked all that stuff to the JVC KD-x50BT head unit and pioneer TS-w303R sub in a sealed enclosure in a Honda civic 2003. The amp does turn on and gives sound for a little while and then goes out. The protect LED comes on and keeps flickring. What I think I might have done wrong is that the infinity kappas are 2ohm speakers and don't do 4 ohm at all. And the sub is 4 ohm and I only have one sub so I could not turn it into 2ohm circuit with 2 subs. So I basically hooked up the speakers at 2 ohm load and sub at 4 ohm load. Given that its 5 channel in one amp, it might have not been able to take 2 different loads. What do you think should be done ? I have returned the amp and am in market yet once again looking for some amp, maybe one or two to drive my 4 infinity 62.9i speakers and pioneer w303r. What do you advice ? what should be done ? should I buy 2 amps or another 5 channel amp ? And if i buy another 5 channel amp is it possible to run 2 different loads on the same amp at the same time (speakers at 2ohm and sub at 4ohm) ?
