Exiled
Ok first question:
I am about to begin the installation I have been slowly building up for the past couple years.
I have an Eclipse AVN52D hu (will list spec reference at end of post), how do I hook up my four(4) amps from preouts on the back of the HU? Specifically RCAs and remote wire...Would I daisy chain them all or would they each get their own rm or what?
Amps: one Exile x300.2, one Exile sm400.4, two Exile x1200.1
The sm400.4 will be powering a component set of 5.25" w/ crossover and tweets as well as a set of 6.5" coaxial speakers. **I would also like to keep the stock tweeters active as well as they still sound nice and are in a great location. ie it would look awkward if the were removed.
The x300.2 will be for a set o coaxial 6x9" speakers
The two x1200.1 amps will EACH be powering a single Exile XP12 woofer. (two subs, two amps)
Secondly, any Hyundai Tiburon owners have any suggestions as to amp placement of the 300/400?
They are all in excellent mechanical and cosmetic condition so I would like to show the off if possible....but I have no idea where they could go (preferably NOT in the trunk).
And lastly, with this Eclipse HU would I benefit at all from adding an extra signal processor and or an additional Equalizer?
Thank you in advance.
Eclipse AVN info in question:
Digital Signal Processor: The unit's DSP offers three sound adjustments for total audio control:
* Soundfield Control: The DSP's Soundfield Control features 5 distinctive acoustic environments to match your listening tastes: Concert, Live, Cathedral, Club, and Theater.
* 7-Band Parametric EQ: Using the touch screen controls, you can adjust the following EQ bands +/-10dB in 2dB steps: Band 1: (63Hz, 80Hz, or 100Hz), Band 2: (125Hz, 160Hz, or 200Hz), Band 3: (250Hz, 315Hz, 400Hz, or 500Hz), Band 4: (630Hz, 800Hz, 1kHz, or 1.25kHz), Band 5: (1.6kHz, 2kHz, 2.5kHz, or 3.15kHz), Band 6: (4kHz, 5kHz, 6.3kHz, or 8kHz), and Band 7: (10kHz, 12.5kHz, or 16kHz). You can select the Q Factor from Q1 (Wide), Q2 (Normal) or Q3 (Narrow). In addition, the unit's EQ has five memory presets for easy recall. You can also set the EQ to Flat.
* Listening Position: The digitally time-aligned listening position settings approximate the ideal position of being equidistant from the speakers. You can select one of four listening positions: front left, front right, all front, or all rear. You can also set the balance and fade volume controls using the touch controls.
Circle Surround II: The AVN5510's offers SRS Circle Surround II (CS II), an advanced surround sound decoder that enables multi-channel surround sound output using surround encoded, stereo, or mono material. CS II features two patented SRS post processing technologies; Dialog Clarity for clearer vocal intelligibility and TruBass for improved low frequency response. CS II works well in the car environment because it is extremely forgiving regarding speaker placement and listener location.
TruBass: SRS TruBass is a signal processing technology for bass enhancement. It uses psychoacoustics and speaker driver physics to increase the perception of bass while decreasing demands on the driver.
Harmonizer: When playing MP3 or WMA files, the Harmonizer helps recreate the depth lost when the files were compressed. Setting options are high, low, and off.
5-Volt, Low-Impedance Preamp Outputs: To assure a clean, strong signal to connected amplifiers, the AVN6600 has 3 pairs of 5-volt preamp outputs with an impedance of 55Ω. High-voltage, low-impedance outputs give you a very high signal-to-noise ratio and a wide dynamic range.
