mageus
I want to replace the HU on my MkII Audi TT with Bose amp and 12 speakers. New HU is JVC KW-AV60BT. I can't keep the OE amp with an aftermarket HU, so I bought a cheap 5-channel amp (RF R600-5). I'm keeping the OE speakers for cost reasons. These are the speaker connections in the stock harness that leaves the Bose amp:
- dash center tweeter (not gonna use)
- door 8" woofers, R+L (4 ohms)
- door 3.1" mid and dash 1" tweeter in parallel, R+L (2 ohms)
- rear 6.5" mid and 1" tweeter in parallel, R+L (2 ohms)
- 5.1" ported sub (2 ohms?)
7 channels. I like a little rear fill, and the kids like music when in the car. Here are some ideas:
- amp drives the door woofers, front mid/tweeters, sub, and skip the rear speakers
- amp drives the front mid/tweeter, rear mid/tweeter, and sub. HU drives the door woofers.
Can the HU's 20W RMS drive an 8" woofer?
- amp drives the door woofers and front mid/tweeters in parallel, the sub, and the rear speakers
Could I use a passive x-over to isolate the impedance of the combined woofer and mid/tweeters? In parallel they would give 1.33 ohm, but a proper x-over would present 2 ohms to the amp.
- amp drives the door woofers, front mid/tweeters, sub. Disconnect the rear tweeter from the mid (so the mid presents as 4 ohms) and drive it with the HU.
I'm leaning toward the last option. I'd split the front pre-out signal to both pairs of channels on the amp, disabling the HU front crossover (use the amp's high pass filter). I'd wire the HU rear speaker out directly to the rear mid, using the HU's high pass filter for the rear mids. I'd send the HU sub pre-out to the amp, and could use the HU's, the amps, or both low pass filters. Too bad the amp doesn't have a band-pass filter for the woofer.
Any thoughts?
No one knows the exact impedance of the stock speakers. I presume that the resistance obtained from an ohmmeter will be lower but close enough to confirm it?
Any thoughts?
