Need a Sub Box for 3 10" subs
hotboy251
20
mobile
I heard your fourm was the best so need a speaker box built for 3 subs each needing the following air space
(the specs below are for each individual sub)
Recommended Minimum Volume (Cubic Feet) - .375
Recommended Maximum Volume (Cubic Feet) - 1.75
Depth Top mount - 4.6875 in.
Depth Bottom mount - 4.1875 in.
Cutout - 9.3125 in.
or do any one know were i can get a prebuilt box that will be perfect for these subs
Rockford Fosgate 10 Inch Sub Woofer
RFZ 2810 - 8 Ohm
p.s. im gonna wire them in parallel for 2ohm load with a Bazooka El1500 for 500watts@2ohms
Ya, usually they dont sell prefabed ones @ Best Buy, etc. You usually have to find a local car stero place, they build it, they have one already made, or you can take a shot @ it. Its not as hard as first timers think it is, just takes time...
Can you all post some pics of your work so i can see whos the best //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i also could build u one. i have some pics in the gallery if u would like to see them. if u want to get a hold of me my addys r in my sig. with out knowing shipping i think i could do it for 65 shipped
Would i benefit from a bandpass box or should I stick with a sealed? is it true that subs in a bandpass require more power to the subs than a sealed or is a sealed just more efficent thx.
Originally posted by hotboy251 Would i benefit from a bandpass box or should I stick with a sealed? is it true that subs in a bandpass require more power to the subs than a sealed or is a sealed just more efficent thx.
i have always hated bandpass boxes, they make the subs sound quieter. i would go with sealed or maybe even a ported box
OK Im gonna try to do it myself wish me luck ill post pics of my progress hopefully ill end up with somthin like this...........
hey, that box is fine, but:::::: you see the speperator pieces on the inside in between each chamber? see they are cut out like that all gay? Make the divider boards solid and put them in, so you don't have the "push-pull" effect going on for all subs, especially bad if one or 2 blow... give them each there own chamber
one more thing the site has the mesurements of the box on the web site should i just use those and my box should be the same right? unless i f#$% it up lol.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
841
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
hotboy251
hotboy251
mobile
more_spl
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
