Need a sub box design
CodyDaGoat
6
OR
I have 2 SA-15s and my audio shop will build a box for me if they have the design for it. I don't know much of designing
I want the box to be port to 33-35hz. I don't want fancy stuff, I just want a standard box desgin.
I want my subs to be loud and to vibrate a **** ton as I like subs doing that, I listen to ghetto rap music with low frequency and like the continuous bass
I have a GMC Envoy, I had a start of 18"h x 37"w x 30"d and for the ports 15.75"h x 6.25"w x 20"d. That's what I had got online for dimensions with a similar size vehicle.
Here are the specs for the sub
RE (ohms): 4.61
FS (Hz): 34.88
Vas (L): 54.69
Qes: 0.72
Qms: 6.52
Qts: 0.65
Le (mH): 3.39
BL (NA): 21.76
Mms (Grams): 338
Cms (uM/N): 61.42
Sens (1w/1m): 86.81
Cutout Diameter: 14 1/8"
Mounting Depth: 7 1/2"
Overall Diameter w/ Gasket: 15 5/8"
Displacement: 0.17ft^3
RMS: 750W
Recommended Box Specs (Sealed): 2.5ft^3 (Yields F3 of 41Hz)
Recommended Box Specs (Ported): 3.5ft^3 (Tune to 35Hz, Yields F3 of 28Hz)
Can someone make a design to give them please
Someone should be along to help but I personally wouldn't trust paying a shop to build a box if they can not design one. Never heard of that before.
Also to each their own but I personlly like to tune around no higher than 31-32 for that kind of music. I like decaf, got160s, and lots of chopped and screwed so I personlly like my boxes at around 28-29 but you sacrifice a little of the top end. Had sa's before and they can for sure dig deep in the right box.
They design them but they charge for it I believe
I was going to give them the box measurements I have and sub specs and have it built
Honestly, if they are a very reputable shop, id let them do it. That way, they cant blame the design later.
People like cscstang do great designs, but honestly there are plenty of ****** forum designers online.
There is a shop local to me in Cali who do better designs than 99% of the forum people. Sometimes great shops get overlooked because the abundance of shitter shops
RE (ohms): 4.61
FS (Hz): 34.88
Vas (L): 54.69
Qes: 0.72
Qms: 6.52
Qts: 0.65
Le (mH): 3.39
BL (NA): 21.76
Mms (Grams): 338
Cms (uM/N): 61.42
Sens (1w/1m): 86.81
RMS: 750W
I can hook you up man. Pm me if interested..
Sent from my SM-N920V using Tapatalk
CodyDaGoat
CodyDaGoat
OR
CSCStang
