Need a spot o' help.......
SKMexiFry
...For a Porkchop, uh...
If I were to wire another battery in my car, does it have to be the same size as the battery that is already in there, or can I wire some big ass battery to it?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
The main concern is your alternator. You can put a 'big ass' battery in your car, but your alternator has to be powerful enough to keep it charged.
Will this battery be in addition to your stock battery? If yes then I would say your alternator could not handle the load. If you're replacing the stock battery with a bigger battery then it may work. The majority of stock alternators are designed to keep the charge balanced on the battery. If you have a truck designed for towing, or some other large type of accessory, then your alternator is designed to work overtime when needed. On the average vehicle, the alternator would have to work overtime almost all the time just to maintain the balance of the charge on a larger battery. If this is the case, I would read up on how to replace alternators if you don't already know. It may only take a few months or it may take a few years, but either way your alternator will suffer.
144
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
450
346
755
SKMexiFry
SKMexiFry
Port Orchard, WA
muffmanaj
    May 16, 2024
    May 16, 2024
