Need a high damping facrot Amp! Plz help
soundstream reference amps Soundstream - Reference Amplifierfind the one you want and hit me up for a price new
---------- Post added at 01:04 PM ---------- Previous post was at 01:03 PM ----------
you can do a 4 channel and a mono block amp
Bro...
Everyone, except the retards that you take advantage of, is tired if this routine where you pretend to offer help that perfectly coincides with the sale of something that you just so happen to peddle. Why don't you make a few threads here and there and allow people to call upon you for your 'expertise' instead of being that annoying little faggot in Best Buy who reminds you every other isle that he doesn't work off commission and he just wants to ensure your satisfaction?
Say I go for these:
8 speakers: JBL P562 5 25" 2 Way 110W RMS Power Series Car Loudspeakers New Pair w Warranty 050036930024 | eBay
Double enclosed tube: Boston Acoustics G112PD 800W Dual 12" Ported Gtuned Loaded Subwoofer Enclosure | eBay
Now what amp and alternator should I get for these? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You don't need to run 8 speakers to get loud. Start with a more simple system that doesn't require you to cut up the car. Those are 2 ohm speakers, which means you either have to run 2 4-channel amps or wire each pair of speakers in series. You'll not actually gain that much output, especially when you'll have such a mess of sound.
Forget about the alternator unless your current alternator isn't charging correctly. It's not needed at this time.
Any good quality mono amplifier that does at least 400W at 2 ohms would be a good match for that subwoofer box. There may be a good value amplifier from Boston Acoustics.
The car comes with 8 factory speakers, no cutting up ;-)
if you can find a real PPI PC they run 500 damping, 110 signal to noise, and the rest of the specs are great to
down side is they stopped making these around 2000. and the new precision power is not the same
great sq amp think the one I have now was made in 1998
You must have the 14 speaker system. You're asking about using 8 coaxials, so that's 8 tweeters. I'm surprised I didn't think about that before, but that's twice as many tweeters most people use with a 4-speaker vehicle.
This is one case where using all available speaker locations is not wise, in my opinion. Modern cars use digital signal processing to make all of those speakers sound decent. The signal processing is most likely built in to your factory amplifier. If you take that out what you're left with is chaos as sound arrives from many locations at different times, and that's just part of the problem. There's no sense in getting loud if it's going to sound like garbage.
You could do one good 2-way component set in the front, a good pair of coaxials in either the rear doors or the deck, and add a subwoofer box in the trunk. This can still get very loud if it's done right.
^ i agree.... I have a bmw 540 with 12 factory speaker locations but i have a component set up front and a pair of mids in the rear with a subwoofer and its amazing ...6 speakers plus sub.... A lot louder that before and crisp
sokolhasan
sokolhasan
United States
momax_powers
