need a break down dual 2 ohm and dual 4 ohm voice coils
Exactly......or you could run 3 svc 8ohm subs (parrallel) or 2 dual ohm subs, or your best bet would be to get 3 more dual 4 subs and wire them in series/parrallel to get to the desired 2 ohms...kinda like this, the amp only sees ohms and not how many speakers it's pushing.lower ohms meanes more power from the amp and/or more subs that can be wired to said power. does that help or confuse the hell outta ya?[/QUOTE]
lol a lil...just let me use 1 sub. 1 dual 4 ohm sub CAN be paired with an amp with a min impedances of 2 ohm and produce more power right? but 1 dual 2 ohm sub woulndt be compatible with an amp that has the min impedances of 4 ohm? am i gettin it?
(1) Dual 4-ohm sub can be wired: In parallel for a 2-ohm load, or in series for an 8-ohm load.(1) Dual 2-ohm sub can be wired: In parallel for a 1-ohm load, or in series for a 4-ohm load.
SPOT ON BRO............ sorry for getting carried away there.
i got it now, thanks for the help fellas...
well yeah..im simple terms...ohm loads is used to match amps and subs/speakers...i know we cnt hear the thd at low levels...but if the sub/speaker is built bad...that little difference can make it go pop....
lorideslo
lorideslo
Hampton, VA
hrtbrk1
