Need a box builder in KS,MO, or N. OK
JKnight
Looking for a box willling to pickup from these states, but will look at all qoutes. I listen to mostly rap and r&b, so looking to go low. My dimensions are 30w x 17h x 15d. Have not bought the subs yet , but depending on the box will go width 2 12"s or 1 15". Subs specs are for the 12"
Frequency Response:
20 Hz - 500 Hz
Power Handling:
600 Watts (RMS)
Nominal Impedance:
2/4 ohms
Sensitivity:
86.8/87.2
Voice Coil Diameter:
2.5"
Dimensions:
Mounting Diameter
11-5/32" (283mm)
Mounting Depth
6" (152.4mm)
Spkr. Displacement
0.13 cu.Ft /3.7 liters
for the 15"
Frequency Response:
20 Hz - 500 Hz
Power Handling:
600 Watts (RMS)
Nominal Impedance:
2/4 ohms
Sensitivity:
87.3/87.8
2.5"
Dimensions:
Mounting Diameter
14-3/32" (358mm)
Mounting Depth
7-1/8" (181mm)
Spkr. Displacement
0.22 cu.Ft /6.2 liters
Have 1200w rms to give them. Would love to go with the 12's so i can fully use my amp, but will go with the 15" if the 12"s will not fit.
You should list the t/s parameters or atleast tell what type of sub these are. It will help a great deal.
Good Idea
Thanks,
Subs will be CerwinVega VMax , i'm able to get a killer deal so I must use these.
Im near wichita, if your interested.
Wichita would be perfect. Could you take a look at the specs and PM any info you might have/need or just a suggestion on the subs. Not really in a big rush on the box, but would like to order sub(s) soon.
JKnight
JKnight
Arizona
JKnight
