Need a Amp?? But what kind i should get
  • 2
Terrance9710
HEY I WANT TO GET THE PUNCH 1500.1 ////// HOW MANY WATTS WILL EACH SUBS SEE.... AND HOW DO I WIRE MY SUBS, I HAVE THEM WIRED IN 2OHMS. IF I DO BUY THIS WANT EACH SUBS SEE 750 X 1~~~~~.
THE AMP IS GOING TO BE PUSHING TWO PERFORMANCE TEK 12'S IN A SEALED BOX. 2OHM, 4OHM, 8OHMS. SHOULD I LEAVE IT IN 2OHM OR WIRE IT DIFFERENT. LET ME KNOW!!!!!!!!
AND TELL ME THIS
MY FRIEND HAVE TWO KICKER L5'S 12 WITH A PUNCH 1000.1 AMP
SO EACH ONE OF HIS SUBS ARE PUSHING 500W A PIECE RIGHT. AND I DON'T KNOW HOW HIS SUBS ARE WIRED.
first things first... LAY OFF THE CAPS!!!
if you have two subs wired to a mono (or bridged) amp then the two subs share the watts evenly. the amoumt of watts put out by the amp depends on the subs ohm ratings, how the subs are wired and the resulting ohm load, etc.
i need to know how many voice coils your subs are and how many ohms each voice coil is before i can tell you how to wire things up.
973
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Terrance9710
Terrance9710
Fayette, MS
imral3
Decebal
    Jun 10, 2024
