Need a 800x4 amp.......
937DYTBOI
TL>you
Lookin to make sum alterations to my setup want to change my high and mids amp to an amp that will deliver some crystal clear power to my inside speakers, im runnin a pair of pioneer premiere 6x9's, pair of pioneer 6.5's and pair of pioneer tweets. Need to know which amp is best to run for the sq factor
Are you sure you are looking at RMS ratings? There is also a great difference in "loudness" in the mids and highs compared to a sub. For instance, I can hear mids/highs pretty clear at ~30 watts (clean from an external amp) while by sub amp is push over 1k watts. I am not sure why this is however, but I think anything more than 2 or 300 watts is very quite loud and is only reserved for items like the boston pros or something.
Ok this is whats in my car right now Pioneer 6" x 9" REV-series 2-Way Speaker with 350 Watts Max. Power , Oversized 6.5" 4-Way Speaker, 240 Watts Max. Power , and a set of tweeters running at Nominal Power: 50 W, wanting to know if the Orion 400x4 is decent
your 6.9's are 80w and your 6.5's look like 50w. I would say a good quality 100x4 would be more than enough for all the sq you're going to get. Obviously you'd want the gains lower for the 6.5's vs the 6x9's.
The 4004 is a sweet amp. It's not 100x4, but it's under-rated at 50x4. I'm sure it would do a good job.
937DYTBOI
TL>you
937DYTBOI
Dayton,Ohio
3.5Max6spd
