Need a 7kw I can run at .35
i'd put my stock on the vital power 100% seeing them IRL. Also seen a dc 7.5k, ampere 7500.1 ddm4a, ampere tfe IRL too not anywhere as impressive. Its on par with the crossfire 8k which walks all over most of the other ones in its class.
I like my vital power way more then my crossfire 8k... vital power loves life at .33ohm daily. The crossfire 8k,ampere 9.0all tan HOTT
I'm run the 3600 for a show to see what I can do then I'm try to see if I can catch that record. It's gonna be hard in this Lil car to get my coupling correct.
I'll sell you my Shocker 4K for 1400 shipped. Will get you into an even lower """rated""" power class. I've been running it .7 nominal for the last year or so daily.
I would not run anything I couldn't afford to throw in a dumpster at .35 ohm daily.
This thread implying that you're efficient at .35 ohm and implying that there's any difference between the popular "8k" Korean board amps.
Also I'm not sure if any org has (rated) power limited classes for wall builds.
Not sure what your talking about. I know efficency won't be much different but it's critical in my case because of my limited power supply.
Usaci and mecca have "rated" classes and the have "clamped" classes as well.
I'm not fimilar with that amp and for 1400 bones used it better do 10k. Lol
Not sure what your talking about. I know efficency won't be much different than but it's critical in my case because of my limited power supply.
Usaci and mecca have " rated" classes and the have "clamped" classes as well.
I'm not fi.ilar with that amp and for 1400 bones used it better do 10k. Lol
All Korean class D amps are virtually identical and none have great efficiency at low impedance.
"4K" rating for competition purposes; conservative 9.8V rating. I replaced 8 Zed Minotaur with it and gained half a dB.
I've got 2 more here that I bought blown I'm looking to raise money to get them repaired, otherwise I would not sell it. It has done very well by my this past year.
It's nice but I need to see numbers
Vital for sure. Addictive is local to me so ive seen a ton of them. And I loathe that company but will vouch for the VP.
And its flat out stronger than the DC. Just make sure you get the version you need. The 12 or 16v model
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
219
665
428
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
481
Papermaker85
Banned
Papermaker85
New orleans LA
Papermaker85
