need 4 channel amp... help ?
newdavid
just purchased
KINGWOOD CRW-8-865
6.5" 4-Way Coaxial Speakers
Purple P.P Injection Cone
Butyl Rubber Surround
40mm Polymide Cone Tweeter & Piezo Super Tweeter
Max Power 600 Watts
Frequency Response 60hz - 22khz
Sensitivity 89 Db
Impedance 4 Ohm
i need a good 4 channel 1000watt amp im new to these things and know nothing
is PYLE a good brand ?
this is the one im intrested in
PLA4140
250 Watts x 4 Output
500 Watts x 2 Bridged Output ( 250W x 2 + 500W x 1 )
Dual Variable Hi/Lo Electronic Crossover Network
Variable Input Level (Gain) Control
Dua Variable Bass Boost
Dual MOSFET PWM Power Supplies
Thermal / Overload / Short Circuit Protection
Power & Protection LED Indicators
High & Low Level Inputs
Gold Plated RCA Inputs
Remote Bass Boost
Remote Turn On/Off
Soft Turn-On Circuit
Protection Circuitry
High Level MOLEX Inputs
Anti-Thump Turn-On
Tri-Mode Configurable
S/N Ratio: 95dB
T.H.D:
Frequency Response: 15Hz- 30kHz
Dimensions: 11.34''W x 2.24''H x 21''L
if its not naygood please suggest some brands my range for amp is 100-150
thanks
First, Pyle is not a good brand. Please direct your intrests else where.
Second, you don't need a 1000 watt amp. You only need a 50x4 amp. So 200 watts.
Third, Those kingwoods probably can only handle 20-60 watts. They are very low end.
I don't meen to talk down on your equipment, but that is how it is. If you are on a budget look in to Profile 4 channel amps to power your coaxils. They are inexpensive, and the better budget amps you can buy.
thanks so pyle is out
i already have kingwoods installed to my stereo which is 50wx4
its already 200watts n the sound is good but not that good
what abt sonyxplod ?
Again if you have it hooked up to the HU they are only getting about 8-12 watts. You are reading the MAX power rating. Ignore that. Look at the RMS power rating. So your only using about 25-50 watts total. Sony's amps are a bit over rated, and get bad reviews.
sony amps ****. i remember when i first started car audio i had a jensen amp and thought i was upgrading to a sony, and it turned out i downgraded //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
newdavid
newdavid
usa
guy022077
