NEED 2 SUBWOOFERS {Details Inside}
focused313
Learning With Every Post
Vehicle - 2003 Chevy Impala
Enclosure - Dual 12" Ported - I don't know the exact specs right now
Desired Wattage - 500-600w RMS EACH (1k watt system)
Amp - NOT SURE EXACTLY but it will be a HIFONICS amp with 1,000w RMS amp running at either 500w x 2 or 1,000w x 1. Amp will most likely run 1,000w @ 2ohms so keep that in mind.
Budget - TOTAL for both subs should NOT exceed $600. $500-$600 is my range, but if I can get two good 500w RMS subs for far less, BY ALL MEANS RECOMMEND THOSE.
I currently have two JLw3's so I'd like decent SQ with good SPL. I am willing to shop online as well as ebay. I'm not TOO picky about brands, but I'm sure this forum wouldn't recommend any garbage to begin with.
Also, will I need to invest in a new battery, cap, or alternator? If so, I'll knock that stuff out before I upgrade. My bass system is currently @ 600w RMS, but that's with the ideal voltage and gain settings.
2x Fi Q 12", 2x Soundsplinter RL-p 12", 2x TC Sounds TC 2000 12" or 2x Stereo Integrity BM 12".
shows how much I DON'T know about the non-commercial brands. I've only heard of the TC 2000 out of the four you listed. Thanks.
because he named ones that dont even fit you right, the tc-7 and Fi ssd's would fit better than the 2000 and q's and be cheaper
yea, I see that now. I like the specs of these FI SSD 12's. Looks like I'll need a 2000w RMS amp with those.
focused313
focused313
Michigan
focused313
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
