Need 2 800x1 at 1ohms amp
RbAudio_Geek
Ok, frist tell me if my calculations are correct i am planneing on haveing 8 4ohm re re's giving them 200rms each and ill be using 2 amps to push them. So i figured having 4 parrel wired to one amp that should give me a 1ohm load right? So than i would need two 800x1wrms at 1ohm correct? BTW how mush cu.ft should i give each RE?
thx
no 4 dvc 4 ohm subs wired in series/parallel would yield a 2 ohm load wired in parallel/parallel would yield a 0.5 ohm load . however wire all 8 dvc 4 ohm subs in series/parallel to end up with 1 ohm load . get one mono amp that puts out 1600-2000 at 1ohm and you'll be good
so its not possible to wire 4 dvc 4ohms subs at a 1ohm load?
No. Think of it like this:
There are only 3 possibilities for a pair of 4 ohm dvc's - that's 1, 4, and 16. With two pairs (4 total) -- No combination of 1, 4, or 16, parallel or series with another 1, 4, or 16 = 4 ohms.
RbAudio_Geek
RbAudio_Geek
Norman, AR
RbAudio_Geek
