Need 12" sub sealed recommendations
towncarblue
bx
i need to find myself a 12" sub that can
be put into a sealed enclosure of ONE Cuft and can handle
around 600-1,000 W rms { kicker zx1500.1 is my amp }
i want some deep bass and vibration { dont care if it gets loud }.
i usually tune the amp's LPF around 80-100HZ {dont have a sine wave viewer}
my budget is $300 but i can go a bit more if its worth it.
I ONLY WANT BRAND NEW SUBS.... not looking to buy used.
ive narrowed it down to three choices.....
either a single ssa GCON 12" OR a single sundown SA-12
OR two sundown audio sd-3 .
AM I BETTER OFF WITH THE SINGLE SUB OR DUAL LOWERED POWERED ONES ???
CAN ANYONE RECOMMEND ME ANYTHING BETTER THAN MY CURRENT SELECTIONS OF SUBS ????
deep bass will require more than 1 cubic feet. 1.25 to 1.5 cubic feet is what i would shoot for if i were you. Incriminator audio flatlyne, tc sounds epic, dayton audio ultimax are good strong low end sealed box friendly subs.
i decided to buy a stereo integrity mag v3. they got good reviews , good price {$200}
and they work both sealed and ported . with the extra money i was planning on building a
ported box of 1.5 cuft @ 35hz as recommended. i used re sub box calculator to find my box specs.
complete box-- 28"L x 15"H x 10"D
port -- square port width .75" , 8.5" x 13.5" , no L-port needed
will a ported box lead to less vibration ? dont care bout loudness.
am i better off just building a 1.5 cuft sealed box ??
154
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
115
461
354
towncarblue
towncarblue
bx
DaytonLax14
    May 16, 2024
    May 16, 2024
