I'm running 2 SPL1291 ULTRA EXCURSION SUB WOOFERS in series from Swiss Audio in the Wicked One Enclosure By Decware with a SDX2000C1 X 2000 WATTS Class D Mono Block Amp from swiss audio
http://www.swissaudioinc.com/frame.html
http://www.decware.com/newsite/mainmenu.htm
Specs:
Proprietary Euro Cast Basket
» 12” Ultra Excursion Woofer
» Power Handling: 700 Watts RMS
» FATT 50mm / 2” Foam Surround
» 110oz Double Stack Strontium Magnets
» Frequency Response: 22Hz - 500Hz
» Efficiency: 93dB
» Voice Coil: 75mm / 3” 4-layer ASV
» Dual 4-Ohm Coil: 2-Ohm or 8-Ohm operation
» Hole Diameter - 275mm / 11”
» Depth - 169mm / 6.65”
Amp Specs:
SDX2000C
» Proprietary “Swissink” chassis design
» 500 Watts X 1 @ 4-Ohms
» 1000 Watts X 1 @ 2-Ohms
» 2000 Watts X 1 @ 1-Ohm
» Full Variable LP X-Over (50Hz-250Hz)
» Variable Subsonic Filter
» 12dB per octave slopes
» Remote Bass Boost Control
» Dimensions: 450 mm (L) x 238 mm (W) x 57mm (H) 18”(L) x 9.5”(W) x 2.25”(H)
