My Sub Don't Work
sumone
Midwest
Yeah...how to fix it?
Just playin'...
12" DVC 2Ohm IDMAX (v3)....both coils are showing an open circuit with a meter. Was running at a 1Ohm nominal to my eD 9.1 with no problem for a year maybe. No (obvious) visual anomalies.
Last couple days sub would go in and out (seconds-length of time) 'til finally it just went out. Verified amp was still putting out a signal...sub is just bunk.
What are my options? This stuff cost $275 when I bought it.
Edit: it's been a little over 2 years and was bought used (was still under-warranty, but not now).
I dunno if there is anyway to contact the speaker itself. lol
But you could call Image Dynamics and see what they say.
Usually they recone it for free within a reasonable time.
Just tell em you bought it new from a dealer.
How do you know a recone is what is needed? What are the symptoms of needing a recone? It sounds like that word gets thrown around a lot (and potentially unnecessarily).
Look over the tinsel leads real good and give them a little tug to make sure that they are not broken....if they are good then is sounds like you have an open coil.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
459
487
594
sumone
sumone
Midwest
wackdogg
maylar
    Jun 2, 2024
    Jun 1, 2024
