My Setup
RidnClean
Love 4 Money
hello CA, i was wondering if this setup is a good one in the making:)
also need some help picking out a few things.
2 AQ HDC315s
4k amp(looking for one)
230-250 Alt
YT under the hood
8 Cubes box made by Terra.
PGRSDs 6.5
250.2 Amp(also looking)
now my question is would a 230-250 alt be good enough? and which company is best to go with?
Would 4k be needed? cause i was going to get the AQ2200. but ppl are saying way more.
Also the total is looking around or above $1k. is there something better out there thats sounds just as loud?
your thoughts would help me out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hello CA, i was wondering if this setup is a good one in the making:)also need some help picking out a few things.
2 AQ HDC315s
230-250 Alt
YT under the hood
PGRSDs 6.5
ur sub amp alone is gunna run you at least 1k.. if not less... depending on new or used..
2 AQ HDC315s that's a great start... What about your electrical... when you add in your amp you are going to go way over 1k LMAO
yeah i'm hoping to get a cheaper amp off here that does 3k or better.
but should a AQ2200 do good until i save up for something better?
yeah 1k is what im shooting for but i know i will go over.
is there any other budget amps you would recommend?
also would a 230-250 alt be good enough?
You probably could go with just a nice 200amp alty and be good. Save you some money as well. Cause at 230-250 you are looking at some cheese, so might want to come down some on that and give you some money for other stuff.
Try and hit up the classified section here. They have a lot of nice used equipment here.
sounds good then. what company though?
yeah i've been on this forum since sometime before christmas but i've never registered lol.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Company for what, Altenator of amp? I have suggest the budget amp in PA. Is going to be hard to find a more budget amp that does decent power. Maybe a directed? I don't know. Like I said, check the classifieds here.
If you ment alty brand, then hit Ohio generators. They have serverd me well. I imagine a good 200amp altenator will run you close to if not over 400 smacks.
RidnClean
Love 4 Money
RidnClean
Washington
bigbangtheory
Mike Mccabe
