My setup please comment
SethPhillips
I'sa Playa
svr glass matt batt
-big 3 with 4ga
-1 run of 4ga back to sub amp (MTX 81000d) w/ 100 amp anl fuse
-1 runof 8 ga to 600 4ch amp 30 amp fuse
MTX 8100d running 4 10 rockford fosgate p3's in sealed box
it deff. sounds like im giveing the subs a run for the money little distortion but just dosent beat like i expected....
this is in a 95 dodge spirit
any segestions?
new subs? i was thinking about picking up 2 10'' L'5 in a seald box?
thanks seth
Depends on the distance you're running the power wires and the quality of the power wires. Cheap power wires don't nessicarily meet american conductivity standards.
your MTX amp suggests a 150 amp fuse. suggesting an RMS power of 1000W. In this case if you're running 4 awg that meets american standard, you should have a distance of less than 8ft. (otherwise you'll see a drop in power)
Knuconcepts, Rockford fosgage and streetwires offer high flow wires that would allow you to extand that range to 9-12ft without drammatic power loss
if you're not getting the sound desired, check your connections and settings. Adjust your gains and see if that helps.
you're 8gauge wire is well within the needed power range. no problems there.
SethPhillips
I'sa Playa
SethPhillips
Northern Utah
SethPhillips
vegang
vegang
