My setup, not emitting sound... :/
  • Thread starter dopefish
  • Replies 0
  • Views 678
dopefish
Okay, here is my equipement:
Pioneer DEH-8600MP headunit
Lanzar Vibrant-416 4ch amp
MTX Thunder-2160 2ch amp
MB Quart DSE-216 components
Infinity 1230w 12" Referance sub
4-way fuse block
Optima 51R 'Yellow top' battery
.75 cu.ft sealed enclosure for the sub, to be remade later at 1.0 cu.ft
8ga wire with a 60A fuse inline runs from the battery to the fuse block; each amp is powerd from this block by 8GA wire with their own 60A fuse. GND connections to the amp are 8GA to a single screw in the chassis, paint sanded off. Remote wires ar tied into the 'remote' and 'antenna PWR' from the headunit.
Audio signal is coming from the RCA low-level outputs of the headunit to the inputs of each amp. The internal amplifier in my headunit has failed due to a speaker short in my OEM speakers. We tested the RCA's on my friends amp/sub and it was outputting which made me start going to RCA's instead of high-level. The headunit itself acts normal in everyway, it just does not output any signal from the amplified wires.
I'm still running cables for the LEFT front-stage however the RIGHT front-stage and SUBWOOFER are completely wired. Below is a diagram of the current state of the system:
Here is the planned outline of the system once complete:
Now the problems...
Last night when I completed the install the amps were not powering on, hoever, I was tired and decided to deal with it later. This norming I jiggled the 'remote' wire a bit at the HU as it was kinda loose in the wirenut I used and the 4ch amp came on when I started the car. The sub amp however was not powered on. I figured I'd see if I could get audio out of the speaker I already had wired up, but nothing was coming out; I switched the inputs on the X-over and no differance. I adjusted the gain all the way up and assured the RCA's were in the correct spot but still nothing.
I need to search up my multimeter and check the wires for continuity and proper power but I'm working all day today. I was wondering if anyone had any ideas as to what I should be looking for. The wires all appeared to be in where they needed and snug. :/
This is in a 1995 Nissan 240sx, I've run new wires to the speakers and am only using the stock 12v/ACC/ant./GND for the headunit, everything else is new wire. I'll post pics once I get ahold of a digicam.
Thanks,
~Kris
dopefish
dopefish
Gem of the Hills, FL
dopefish
