My new ALT arrives today!!!!!!!!!!!
1 amp at idle? You won't be going very far with that amperage.
I hope your not going very far at IDLE numbnuts!! It's not a big deal if you don't jam your stereo vey long while idling, which I don't. Besides I can (litteraly) touch the gas and be at 3000+ rpms. Also, it helps that I have a aftermarket flywheel //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Here's a lil run down of what it puts out.
1600rpm---> 1.2 amps
1800rpm---> 1.1 amps
2000rpm---> 1.1 amps
2500rpm---> 37 amps
3000rpm---> 74 amps
4000rpm---> 121.2 amps
5000rpm---> 144.1 amps
6000rpm---> 156.1 amps
7000rpm---> 163.6 amps
8000rpm---> 168 amps
turn on speed 2000rpm
regulator activation speed 1100rpm
Voltage set point 14.407 //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Now to put the bi*ch in.
are you sure these specs are right?
guys remember that the alternator itself spins much faster than the engine does...
You know what, I always thought... that dogs.. laid eggs... I learned something today. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Good to know //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif does the difference between engine and alt rpm depend on the specific car or is it all the same ratio?
its gonna differ with the different sized pulleys on the alt and the crankshaft pulley
crankshaft pulley diameter / alt pulley diameter = how many times faster the alt spins than the engine RPM. My engine has a ~6" pulley on the crankshaft, and a 2" pulley on the alt (couldnt measure the crankshaft pulley very well due to location) My alt spins roughly 3x as fast as the engine does.
i learned how pulleys work way back with legos //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Stillmatic22
Stillmatic22
Dallas, Tx
Meh!
