my idea with EDU 700's
vosschs
Banned
first off i meant EU 700
im getting a pair, heres what i plan do to. Tell me if it sounds like a good idea or bad. I already run a 12 ported at 29 hz. I want to add the 6.5's in my trunk so what I plan to do is where in my backseat there is a center counsol thing that folds down to go into the trunk. its about a foto wide by 15 high..... im going to make a box that the front peice goes right into that so i can see the subs and have the port face back. im gonna run them at 150-200 wrms ....also with the second amd.... im gonna get a distro block for the power and run another ground... is it better to run another set of RCA's or is it the same as just getting a splitter putting one pair into 2. thats what id rather do. also with the remote can i just splice another one off of the one i have ran already?
so you're basically just wanting them for a midbass......
why not put them in the front?, w/ sound being stereo if they are right beside eachother in the middle of the car your imaging might get screwed (someone correct me here, i know that i don't remember everything about this, so someone step in)
hmm i dont really have much room for them in front,,.... doors are no option.... maybe a kick panel type deal.... i kinda like the idea of them in the location of the part that folds down in the backseat..... thanks for your opinion ill take all i can get
If you run them at anything more than 70-80hz, you'll be ruining your front stage. And your 12" should easily cover up to 80hz. Basically if you want a 3 way system using 700s as midbass, then they need to be up front. And if you want them for subs, then you don't really need them and the 12 both. It sounds like you want them for midbass, but the higher you cross them over at the worse it will sound.
just put em in the back and use them as a dedicated sub.
PS
Those *****es were packed up ****in solid and if usps still manages to break em, ima go pat them on the back //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
vosschs
Banned
vosschs
just east of STL
vosschs
